Discuss millwauke angle drill in the Electrical Tools and Products area at ElectriciansForums.net
loplug
any one have any experience of these I have the 18v combi drill impact and sds which I am impressed with the sds so much so I have retierd my bosch 36v. thinking of adding an angle drill for drilling out first fixes.
I wouldn’t have thought so. The hole hog looks the dawgs lol
If I had enough use I’d grab the de walt flex volt equivalent probably. Cos I’ve got batteries for it already.
Most angle drills will cope up to 20mm quite efficiently. The hole hawgs are different beasts altogether though, depends what you need them for. There are 2 versions of the hawg, both a lot bulkier than an angle drill, but hugely smaller than the dewalt version. That looks like it needs to be bench mounted.
I could only justify one if I used it daily to be honest.
I purchased the hole hawg. It is great, but only as good as the bits you use. Try the bosch self feed spade bits. They make light work of drilling joists.
Also found that the hole hawg doesn't use as much battery as a combi drill does drilling joists.
Powertoolsgb.co.uk currently selling it for 218 quid inc vat. I paid 250 for it so that's not bad deal.
Would definitely recommend it.
I have been using the bosch self feed bits agree that the make light work of it
Reply to millwauke angle drill in the Electrical Tools and Products area at ElectriciansForums.net
I’ve decided to buy my brother some drills for him going self employed. Now I was thinking either Makita or possibly Bosch Professional: Some...
5K
So back in the early around year 2000, I was a data networks installer and had a Bosch 24v SDS drill, it was awesome, did pretty everything I...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
I’m new-ish to the trade and going to be working on site in a new build block of flats as an Adult trainee/apprentice, I’ve been told to bring my...
5K
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
