Discuss Mini sun downlights - any good? in the UK Electrical Forum area at ElectriciansForums.net
peterhyper
I have loads of 12 volt downlights to replace, and Mini sun are the ideal size with a 65mm hole required for them. They are fire rated, but my issue is that because some are going in bathrooms (all chrome), I don't want them getting pitted after a year or two as I would feel obliged to replace them.
If they are not any good (they are quite cheap), does anyone have any suggestions for chrome downlights that fit into a 65mm diameter hole (they can't be intergrated?
i have fitted loads of minisun GU10s and only had a few fail (after a few months).
Yes they do them in chrome. Why would the customer want gu10 over intergrated?
Most of my customers prefer removeable GU10 rather than integrated when given the choice. If any fail then they just replace the bulb rather than the whole unit. Plus you may not even be able to get a matching new unit. I expect integrated are better quality and designed to last, but some will fail.
Reply to Mini sun downlights - any good? in the UK Electrical Forum area at ElectriciansForums.net
Hi I wanted some advice regarding which downlights company is better from ancell or forum? I have builders doing works in my house but I wanted...
Hi all, I bought a house and went around replacing the mr16 halogen downlighters with LED lights. The lights are controlled by a Quinetic smart...
Just popped round to a neighbours house, they have several of these in the kitchen that have failed...
Hi, hopefully someone on here can help, I'm going crazy trying to figure this out. I have 5 x old lights in my kitchen, like old round mushroom...
Hi I am a DIYer, but I did have electricians training about 45 years ago. I'm installing LED downlights (IP65) in my upstairs bathroom. I have the...
