- Reaction score
- 7,230
Hello people
I need a bit of help confirming Minimum Working Space around electrical enclosures.
For example: 10A 1PH 230V enclosure mounted on a structure with a hand rail in front of it, in an EC country.
What I have been using for the minimum distance between the enclosure and the hand rails is EN60204 section 11.5 (Access to controlgear) which states:
In cases where:
equipment is likely to be live during access; and
conducting parts are exposed,
the clear width shall be at least 1.0m.
I say that there should be a minimum distance of 1 meter between the enclosure door and the hand rails.
I have a work college who says that this section is not relevant and the regulation was brought in regarding switch rooms in paper mills where the whole switch room had exposed copper bus bars.
Who is right?
I am happy to be wrong if someone can tell me the regulation I should be working to.
The American & Canadian regs are very clear (American Table 11.5.1.1 & Canadian Section 2-308)
Many thanks
In cases where:
Who is right?
Many thanks
