Discuss Minor Works and three phase in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
DanBrown
Does a Minor Works Certificate also apply for three phase? as under the essential test's section, it doesnt mention anything about L-L Insulation resistance test!.
A minor works is defined as any electrical work that does not include the provision of a new circuit. Therefore yes it does apply to 3 phase.
The forms in BS7671 are model forms and therefore do not include all of the result of tests that you may have carried out. For example the test results schedule does not include r1,rn and r2 boxes for the ring final circuit tests whereas the NICEIC forms which are based on the model forms in BS7671 do.
Hope this helps.
Reply to Minor Works and three phase in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All I have been asked to supply a minor works certificate on a smart thermostat upgrade. Would I just test the dedicated circuit from the CU...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Why the main three phase doesnt have a neutral wire before reaching a stepdown transformer, how does electricity form a loop back to its source
Evening all, I just wanted to see if electrical improvers/adult trainees with appropriate levels of experience and who hold testing...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
