Discuss Minor works in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
JohnB
Do I need to be a member of a competent persons scheme to do minor works, I have to put up an outside light with the feed coming off an existing circuit??
in a word, no. as long as the light is fitted to the building with no exposed connections outside, it's not notifiable. if you are coming off a socket circuit ( ring or radial) remember to fuse down via FCU. use a double pole one so that if the outside light should get water in, client can isolate both L and N just by switching it off.
Reply to Minor works in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
  • Locked
Required asap for price work. No of Workers: 2 Location: Brighton & Hove Description of Work: Installation of 230v operated, radio linked smoke...
I am currently going self employed. I was never put through any 18th edition courses, so have booked myself onto my 18th wiring regs. I want...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
