Discuss minor works in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As far as i was aware, and long as not moved or installed a new supply a minor.works doesn't have to be issued?? But dont trust just me im only a apprentice :p
Not something i would know too much about, but as far as the customer is concerned it would be more professional to issue such a certificate whether it was required or not!! Not as if we would be talking about just one or two light fittings is it, but the whole or the majority of the shop if i'm reading your OP correctly!!
I agree E54 its going to look a lot more professional with cert...
Not like swapping a light fitting in a domestic where quite a few just record Zs on invoice...
Id recommend you issue a cert...
Reply to minor works in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Evening all, I just wanted to see if electrical improvers/adult trainees with appropriate levels of experience and who hold testing...
