Discuss Mixed conduit grounding question in the UK Electrical Forum area at ElectriciansForums.net
mkemp590
Hey all,
I'm running a few outlets to my basement from the main panel on the first floor. Since it is a garage, sealed 3/4" pvc conduit runs through the concrete into the basement. This connects to a metal junction box and 3/4 emt, with metal junction and outlet boxes the rest of the way. There are two 20 amp circuits and one 15 amp circuit for the lights. I know that I can use the emt itself as the ground path as long as it is connected to the main panel. My question is: Would it be code compliant to run one ground wire from the main panel, through the pvc, to the first metal junction box, and then ground all of my outlets to their outlet boxes further down the line?
Thanks for the input!
-Matt
Run a ground wire throughout AND bond to all metal boxes with ground screw or at least to the outlet itself. Using EMT or any conduit as a ground or bond has been against the NEC (US code book), for any new installation, a good long while. The ONLY exceptions are if you don't touch it, or install a GFCI & bond to the box.
The path to ground is the most important circuit in an electrical system. I would call a local electrician for advice as to any local codes in your city/state that I maybe unaware of.
Good luck
Hey all,
-Matt
Matt PVC or not you are required to pull 1ground wire per raceway sized to coincide with the largest conductor
Reply to Mixed conduit grounding question in the UK Electrical Forum area at ElectriciansForums.net
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
