Discuss MK Egatube boxes in the UK Electrical Forum area at ElectriciansForums.net
Andy.D
Hi all,
A question that I’ve seen come up a few times on here & other forums is can you get plastic flush boxes? Usually to replace rusted galv boxes in damp walls.
Has anybody used the MK Egatube conduit system? They have plastic flush boxes as part of the range & I’m on the look out for some for the same reason as above. I’ve attached a pic showing them in the catalogue.
A quick google search comes up with nothing & I’ve asked a supplier but still waiting on an answer. Any ideas where to get them please?
Cheers Andy
Haven’t seen Egatube in a long time , it will almost certainly be special order from the average wholesalers
I used to get all my MK stuff from Edmundsons but now tend to use other makes
Hi all,
Cheers Andy
Andy try homedepot. Com if you can get it
We use Marshall tufflex , if my memory is correct egatube were the first to manufacture plastic conduit. Unfortunately I am old enough to remember the launch of plastic conduit. In Certain situations plastic tube is superb.
When I first went on site in the mid 1990s all the old boy sparks always referred to any plastic conduit as ‘egatube’
Much like many new breed reference plastic flexi conduit as ‘kopex’
I don't think the ega ones are made anymore. I have tried to get flush plastic boxes myself and failed. Builder I work with is of the opinion that plastic should be used when plastering with lime , which is starting to happen more often now.
you mean a builder is actually plastering and not dot and dabbing crumble board?
You will probably have to contact some of the big national wholesalers and see of they have any old back stock of the stuff.
I know Edmundsons back in the day used to hold a fair amount of old MK stuff , like old grid stuff and trunking etc
Reply to MK Egatube boxes in the UK Electrical Forum area at ElectriciansForums.net
I know I’ve seen them before…. But I can’t think of a name. I’m needing a line of metal back boxes in a kitchen… 2 lots of 2x 2 gang and a 1...
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
I have a customer who lives in a grand old house which suffers from damp. The ground floor sockets (2 different circuits) IR test at around...
8K
I commissioned an EICR to be done on a property that is in Wales as this is now a requirement in order to let on any new tenancies after 1st...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
