Discuss MK or crabtree? in the Industrial Electricians' Talk area at ElectriciansForums.net
MK all the way...Spurs are a dream..Grids are quick,terminal screws rarely chew off.Mcb's used to fit in Merlin kit and vice versa,not sure if they still do tho.And Screwfix knock it all out cheap.
Normally MK. Mind you had bad experience this week with Domestic CU(17th ed!!!!). Seems to be made from cheaper plastic than I remember. Probably in China.
mk having two different sockets (dual earth single earth)is annoying and i find grid switches annoying
also watch out for sharp edges on the sockets
Reply to MK or crabtree? in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi, looking at ranges from MK, and BG, tend to be square, or crabtree, Schneider, very rounded. What do you fit to make house reasonably up to...
Opinions on this Crabtree TP 10 way board? Got to test this next week after a quick recce on a clients site yesterday. Although probably...
Hello - hope someone can advise please. I have a recently purchased second hand Myford lathe which has a 3-phase inverter (Siemens Micromaster...
Does anyone know offhand which SP MCBs are compatible with Crabtree Powerstar 3Ph boards? I need to take a 60a supply from this board but I can...
