Discuss motorized valve connections in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
am i right in saying brown switch wire to open valve, blue neutral, orange permanately live, grey feed to boiler?:cool:
Not quite.
For a 2 port zone valve is as follows.
Grey = permanent live feed to valve from wiring centre
Brown = switched live into valve from clock/stat
Orange = switched live out of valve to pump/boiler
Not quite.
Thats the way I have always done it, some of the valves also have a white wire which is rarely used, I wouldnt have thought there was any difference in whether the grey or the orange is live though as I think they are volt free contacts
The white wire is only present on a "mid position valve" and is used as a hot water off signal from the stat to allow the heating to run seperately.
There is a difference in the connections as the grey powers the motor in the valve and the orange is on the load side of the microswitch.;)
As I thought, the microswitch is voltfree, so theoretically it doesnt matter if you use grey or orange as live. white is not only on mid position.Please see link below
http://content.honeywell.com/uk/homes/FAQ/2port.pdf
Reply to motorized valve connections in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
I had to wire in an extra 2 port valve today to protect a newly installed unvented cylinder (replacing the old gravity fed one) in a standard Y...
(Or that might be should a failed HW valve keep boiler running) Woke up this morning to find the boiler still running even though all timers off...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
