Hi,
I need to move a two way light switch from one side of a breeze block wall to another.....there isn’t enough length on the existing cable to feed it though. So I’m going to need to use electrical blocks to extend the cable, then feed the new length through. Do I need to use an electrical block for each individual cable or can I group them together and then use a single cable on the other end of the block and just feed that through. If I can what grading of cable would I need?
any help would be appreciated.
thanks
Dan
thanks
Dan
