Advertisement - Content continues below
Discuss Moving a bedroom light in the Electrical Forum area at ElectriciansForums.net
I am about to move into a flat with loft access. The light in one of the bedrooms is about 2 foot away from the window. Ideally, I'd like to move the light to the center of the room.
If the cable needs to be longer in order to move the light can I use a terminal block to extend the cable or not?
telectrix
Mentor
connections must be enclosed in a suitable junction box. if there's only 1 cable, it's a simple task. however, depending on how the circuit is wired, there could be 2 or 3. this is where you'd be advised to call a local spark. it's only an hour's work at most.
Spoon
Mentor
As above.
How many cables are going to the light?
  • #4
Thanks for your replies. Not sure how many cables are going to the light. I'll find out soon when I get the keys and go up into the loft.
Spoon
Mentor
Just out of interest, the reason why light were placed nearer the window was cause curtains were thinner and the light nearer the window casted less of an image when looking from outside.
telectrix
Mentor
watch out for them spiders.:p
Spoon
Mentor
Don't go poking your fingers under the insulation, trying to find the light fitting, without the electrics for the light off.
SJD
Mentor
How old is the property (light close to window tends to be older properties)?
Apart from it being likely there are 2 or 3 cables, you need to be sure there is an earth present if the new fitting is going to be class I metal. Older wiring might not include an earth.
David Prosser
"Move in to a flat" would suggest you are or about to be the tenant, not owner. May be wise to check with landlord first as most aren't keen on non registered electricians (or tenants) working on the properties they own. If they are happy for it to be moved then get a electrician in to move it. An hour or two should be all that's needed.
ipf
Mentor
Looks like a room that has been chopped in half.
...and partitioned.... wonder about the other half of the window?;)
..and if it has there'll have been electrical work done already, in the other room.
  • #14
haha that's the photo from the estate agent website. That photo only shows half the size of the room
  • #15
I'll be owning the flat not renting it.
Electrical2Go - Online Electrical Supplier
Reply to Moving a bedroom light in the Electrical Forum area at ElectriciansForums.net
Aico Carbon Monoxide Detectors
Top Bottom
