Discuss Moving a bedroom light in the UK Electrical Forum area at ElectriciansForums.net
lknights1987
I am about to move into a flat with loft access. The light in one of the bedrooms is about 2 foot away from the window. Ideally, I'd like to move the light to the center of the room.
If the cable needs to be longer in order to move the light can I use a terminal block to extend the cable or not?
connections must be enclosed in a suitable junction box. if there's only 1 cable, it's a simple task. however, depending on how the circuit is wired, there could be 2 or 3. this is where you'd be advised to call a local spark. it's only an hour's work at most.
As above.
How many cables are going to the light?
Just out of interest, the reason why light were placed nearer the window was cause curtains were thinner and the light nearer the window casted less of an image when looking from outside.
Don't go poking your fingers under the insulation, trying to find the light fitting, without the electrics for the light off.
How old is the property (light close to window tends to be older properties)?
Apart from it being likely there are 2 or 3 cables, you need to be sure there is an earth present if the new fitting is going to be class I metal. Older wiring might not include an earth.
"Move in to a flat" would suggest you are or about to be the tenant, not owner. May be wise to check with landlord first as most aren't keen on non registered electricians (or tenants) working on the properties they own. If they are happy for it to be moved then get a electrician in to move it. An hour or two should be all that's needed.
Looks like a room that has been chopped in half.
haha that's the photo from the estate agent website. That photo only shows half the size of the room
I'll be owning the flat not renting it.
As above, surely must have been split into two at some point? Who would put a light fitting there?
Out of interest, the houses on our estate were built in the mid to late 1970s and they also have bedroom ceiling roses near the window. It really put a damper on my 'shadow antics' when we moved in.
Same here mate.
Has this wonderful pattern artexed onto every ceiling.
Reply to Moving a bedroom light in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
