A
Adam Bunting
Hi all, I'm after some thoughts on moving a meter and main fuse, the fuse and meter is mounted on a board which is obviously screwed to the wall. There is roughly 2m of incoming armoured above ground, so what are your thoughts on pulling the fuse, disconnecting the tails coming out of the meter relocating the the board where I need it then reconnect? I know there's issues with tags but the sparky that put the new c/u has already cut both tags on the fuse and meter to upgrade tails, I can't really see any problems because I'm not having to do anything on "there" side, what are your thoughts?
Thanks,
Adam
Thanks,
Adam
