Customer has asked me to move a light switch from one side of a bedroom door to the other. The door has been rehung so now the hinges are on same side as light switch and the switch is behind the door. There is no RCD protection at all in the house and it is a Victorian property so likely to be lath & plaster construction for internal walls. Am assuming cable comes directly from ceiling down to existing position of switch. Am also assuming if I re-route cable across top of door then the cable will be out of zones (zones being 150mm from corners and ceilings) and no longer vertical, so circuit would then need RCD protection. Can I re-route the cable along the top of the wall (within 150mm from ceiling) and then vertically down to the new position without adding RCD protection? I have no idea at this point (verbal instruction only) about whether access will be possible from the loft.
