Discuss Moving switch. in the UK Electrical Forum area at ElectriciansForums.net
K
kaybee38486
Hi.
Hope someone can advise. Moving a light switch from an outside shed, through the wall and into my utility room. Have drilled through and re-connected switch but now have no lights in shed but do have in the utility room. Is all connected up exactly the same. Seems to be where we position it makes a difference.
Thanks.
K
You would have to give a bit more detail on what effect you are attempting to achieve, e.g. switching existing lights from new location only, adding lights to existing switched supply, changing the switch to operate utility lights instead of shed lights, etc.
If the only change is the switch location then I would expect a loose connection in the junction where the cable is extended or at the switch itself.
Reply to Moving switch. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
