Discuss Multi function tester accuracy record template in the UK Electrical Forum area at ElectriciansForums.net
i can't be arsed any more. it works, it's good. spent too much of my life worrying if the meter is 1% out. never had all this crap with AVO 8 and wind-up Megger. needle points the right way, next job.
I’ve just started a new job, testing smoke extract systems (got the job through this forum as it happens).
Some of my instruments are suitable for the work, some aren’t.
I will also need to to purchase a battery tester, as the 2 I have don’t give a value for Amp Hour capacity, just a pass or fail.
The other instruments that I do have which I will be able to use are an old Amp clamp and a stand alone IR tester.
Seems I will have to get 3 instruments checked annually now to fill out the paperwork.
my local YESSS does 2 free calibration days each year. so in a 2 year span, i get 4 testers calibrated for nowt, and free coffee and a bacon bap each time. then an excuse to call at the pub on way home.
Reply to Multi function tester accuracy record template in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, Had an issue at a recent survey where doing a quick check and found we had pme with a reading of 0.44 ohms. Called the network and they...
Hi I’m just starting to do ev chargers so it’s looks like I need new tester. I currently have Megger 1711. So I can’t do a 6ma rcddc test. I...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi. I've been asked to install a Dimplex qm150 storage heater for a customer. There is a suitable existing supply for the off peak element...
Hello All Strange question for you, I know you don’t have crystal balls :) but can anyone give me any clue on the following… I have mid eighties...
