Discuss multi room music in the Home Media Centre Forum area at ElectriciansForums.net
danzor
Mentor
I know there's topics on this already, but can't find what I am after.
I like the sonos system, my understanding is you have a sonos amp, which then feeds zone players around the house, where each zoneplayer supply's the chosen room?
I was looking at the wired system, if there is such a thing.
Basically wire every speaker in the house to one point, then this should bypass the zoneplayers?
I could be completely wrong, someone shoot me down :wheelchair:
It is pricy stuff, if you have to ask then in all probability yor customer can't afford it. I have only ever installed it for high end clients in £1M+ houses. I have a price list but you have to get in with the dealer. If you phone them up with your requirements you will get a price though.
Reply to multi room music in the Home Media Centre Forum area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Summary (TL;DR) Several lightbulbs in my home supplied by one circuit breaker dim over time and go out in about a year. Right now, the ceiling...
I can't find a previous thread on this topic, so here goes. There is one sort of house-brick that I dread encountering in my area - they are...
Hi guys, Do you know if I can install a Nest E with the heat link in the airing cupboard as opposed to the room stat position? System is a S plan...
