I
ian-d1
I all, just joined up and naturally have a question, but hi first
I have purchased a "cheap" multimeter today as I need to trace a drain on my car battery. The problem is that I need to test the amps constantly over a 20 minute period and unfortunately the unit I have says UNFUSED and MAX 10 SEC EACH 15 MIN which I persume is why after about 10 seconds the unit stops reading the amps.
Is there a method of getting around this, such as placing a fuse between the connection; or would a FUSED multimeter be a better option as I can always take this one back. I presume it is possible to monitor amps over that length of time (the amps will be around 2.5 max) with a multimeter, just like you can voltage.
