Discuss Multimeter to check Light wire in the Electrical Tools and Products area at ElectriciansForums.net
voltage of 3 phase
Voltage can be measured with either an analogue or digital multimeter, analogue just takes a little more skill/knowledge to read the value correctly.
Whatever meter you use make sure it is suitably rated for the application, I think Cat3 600V would be the minimum suitable safety rating. Most decent multimeters intended for this sort of thing tend to be Cat3 1000V/Cat4 600V
As @davesparks has said the most important thing is the meter is safe for use on high energy circuits (i.e. suitable CAT rating) otherwise if you set it to the wrong range or there is a surge during the test it can literally explode in your face.
This is an article written in the USA, so slightly different rules and practices compared to the UK, but the underlying principles are the same. There are a handful of detailed examples of serious accident investigations to provide a feel for the nature of what risks are out there, and there is one very relevant "Hispanic Factory Workers Dies of Burns After Improperly Testing a 480-Volt Electrical Bus Bar" on starting at the bottom paragraph of page 53 and continuing through to nearly the bottom of page 55:
can't beat an analogue meter. the ones with valves in give a smoother resonse on the moving coil mechanism. i stilluse one made in 1934.a wipe with furniture polish on the oak case keeps it "smart".
Reply to Multimeter to check Light wire in the Electrical Tools and Products area at ElectriciansForums.net
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
Saw this on Irish Consumer site (CPCC.ie) HERE Not sure about the rest of the UK but worth checking if you have one. Fluke Europe BV recalls to...
Hey, I want to use an old xbox 360 PSU- 12V 175W output- for my 12V sup pump (pump/air compressor). When I connected the PSU to the pump...
It looks like there's a safety issue with the Fluke 87v multimeter. You can read about it HERE and HERE
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
