Discuss multiple 2 gang 20 amp outlet box wiring on new gfci breaker in the UK Electrical Forum area at ElectriciansForums.net
drounds67
I have a question on wiring to make sure I am doing it correctly. I plan on adding a new GFCI/AFCI 20 amp circuit breaker to my box and run the wires to the first 2 outlets in a 2 gang box I am installing. I am also installing 2 other 2 outlet boxes. This is in a finished garage. I know how to do this in a single outlet box situation. Where the power source line and neutral goes on the corposjdning upper screws on the outlet and the wire going out to the next box connects to the lower corospondeing screws. Of course the grounds from the two wires are connected with a jumper to the outlet and then grounded in the box.
My question is with two outlets to connect before going out to the next box do I just use jumper wires connected to a common connection wire with a wire nut on it. So for instance I would have the 2 black wires from the power in and the power out wires connected to two jumpers going to the outlets all twisted togther with a wire nut on it? This doesn't seem like it would be correct. Any advice would be a helpful.
The reason that you have wire nuts is because that you are not allowed to put 2 wires on one screw. If you are just adding receptacles then you shouldn’t have to use wire nuts if you are going from receptacle to receptacle except in the first existing box. By the way the gold screws are for your live wire and the silver screws are for the neutrals
Reply to multiple 2 gang 20 amp outlet box wiring on new gfci breaker in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
20 Amp outlet (240v) appears to be connected to 30 amp breaker. Is this safe? Was hoping to use the outlet for an EV Charger. I am new to the...
Hello. I am new to wiring and could use some help getting this circuit wired in the kitchen . I am trying to get the source power to the GFCI and...
