Discuss Multiple circuits in one enclosure in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
kingeri
So I am at a job right now to fit downlights in a bathroom (I tried to talk her out of it), and have easy access via loft above. Isolated upstairs lighting circuit. Wiring in loft is very neat, there is a Line enclosure present, all cables neatly clipped. However, on inspection I have found that inside the Line enclosure there are three different circuits, lighting, ring final and smokes. I wouldn't dream of doing this.....would you??
put the RFC in a separate enclosure. ditto with the smokes if they're not on the lighting circuit.
Nothing wrong with it.... What happens when you move a DB and mount an enclosure full of DIN rail connectors. I think the most circuits I have had in an enclosure is 30 odd.
This was going to be my post,but I read yours before hitting the button :sailor:
How often on here do we read that a consumer unit is to be changed which will require extended circuits,the solution presented is an adaptable box to extend the various circuits enclosed in that junction box
but in kingeri's case, where this is in an attic, he isolates the lighting to work on that circuit and then to be safe, he needs to isolate other circuits as well. i think they need separating, even if not against regs.
Nothing "wrong" with this as such. But you should label it as requiring more than one point of isolation before opening. Put a label on the CU too.
I've seen something similar in a bungalow where the Cu had been moved out the kitchen to the hall and all the circuits needed extending. The standard of workmanship was very poor in that case.
A consumer unit is an enclosure and that has multiple circuits? I don't see a problem, if it was on different phases though I would use a 400v sticker on enclosure cover.
there' s a bit of difference here. when you open a CU, you expect multiple circuits. when you open a line enclosure in an attic, you don't.
but then you would not expect a RFC circuit to be in back of a light switch, would you?
I wouldn't really call it best practice to lump a lot of circuits into one JB if there's no need, bet it looks like a right birds nest in there. Not difficult to use three separate enclosures and mark them up accordingly.
my thoughts exactly. line enclosures are only a quid or so apiece, so it's a no brainer.
Thanks for the input guys. It was a Line enclosure (as in our forum sponsors). Didn't mention that the the RFC and lighting were connected in terminal blocks, and the smokes cable literally and pointlessly just passed through the enclosure! It really is bad practice in my view to have more than one circuit in a junction box/enclosure, especially when it is completely unnecessary. As Tel said, there is no comparison between such as a junction box and a CU....the CU would be totally isolated before removing the cover anyway. A JB could easily still have live parts inside even if you thought you had isolated the correct circuits. Just seems like adding an extra danger for no reason. As for labeling the JB and CU....why not just do the job right in the first place! Just my view. :bucktooth:
if you translate the red bit of my signature, it's appropriate.
Not saying that I would ever do it by choice, but as long as it had a '2 or m ore circuits present label' is it really that wrong?
wrong?
in an attic, seeing by a £3 LED head torch, itchy poo up your nose, and you'll see a label that in 10pt type. i trhink not.
Reply to Multiple circuits in one enclosure in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
Hi Im an apprentice and just wanted to clarify domestic style wiring since i work industrial and don't deal with conventional wiring. in college...
