Discuss Multiple circuits passing through an AC isolator in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Multiple circuits passing through an AC isolator what code is this on a U.K E.I.C.R?
It’s a 3 phase isolator with 2 circuits passing through it 1 supplying the isolator I.e 7L1-3 and another circuit 8L1-3 passing through it and on to another isolator 1 meter awayWelcome to the forum mate.
As above, more info is needed.
Out of curiosity, after telling us more about the situation, also tell us what code you think it should be and what regs it contravenes.
Not ideal, should be labelled, needs improvement C3It’s a 3 phase isolator with 2 circuits passing through it 1 supplying the isolator I.e 7L1-3 and another circuit 8L1-3 passing through it and on to another isolator 1 meter away
Reply to Multiple circuits passing through an AC isolator in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
