Discuss Multiple USB outlets in restaurant in the UK Electrical Forum area at ElectriciansForums.net
streamer
Hi everyone
I'm busy rewiring a restaurant and the customer has asked for USB outlets at each table. I think it's a terrible idea - I'd be happy for my phone to go flat when eating out - but that's not the point! The type he has asked for are just USB outlets and not the ones combined with 13 amp sockets and there are 13 of them to be installed.
My question is what sort of loading could potentially be on them? They say the output is 2.1 amps and 5 volts so is it a simple case of that being 10.5 watts therefore 10.5/230=0.0456 amps?
10.5 watts is correct for 1 usb. when you have 13 that's 136.5 watts. no problem at 230V but if you step down to a 5V common supply, it's 27A @ 5V.
Thanks @telectrix, that's what I thought. They are 230v input so the most that can be drawn on the circuit is 136.5 watts.
[automerge]1592583190[/automerge]
Where you been, Streamer?
I’d separate them up a bit. Ie, not all on the one rcd. They always seem to cause problems.
I've been hiding! I've actually moved from sunny Coldstream to the big smoke of Glasgow, just finding my feet here and trying to get a few jobs in.
Got any jobs needing finished over this side of the country?
Not really, I had a mad couple of months before I moved trying to tidy things up, and then the lock down made things even more complicated. But I've had a good few weeks working on the new house and garden and now just getting some work in over here. Are you keeping busy enough?
Just started back last couple of weeks. Odd days here an
A lot of my ongoing jobs are still to go back to, customers are wary.
Couldnt get any SE income support, so had to claim UC.
Yes, but you should allow a little for inefficiencies in the transformation/rectification etc.
But either way it adds up to a couple of hundred Watts total.
Depending on exactly how things are being installed I'd be inclined towards running a 6A circuit to feed them. Otherwise put them on a general socket circuit via FCU's
Reply to Multiple USB outlets in restaurant in the UK Electrical Forum area at ElectriciansForums.net
My GE “Vintage Style” led light bulb glows noticeably brighter when bass kicks in on amplifier, connected to 4 1-15 watt speakers in parallel. The...
  • Locked
5K
Hi Everyone, I'm new to this forum and am hoping someone can give me some advice, as I'm absolutely clueless when it comes to these things. I'm...
220 vs 240 outlet questions I have a question understanding the difference between 220 volt outlets and 240 volt outlets. I saw a video online of...
7K
Good Day, everyone, I came across this forum and thought this would be the place to ask my questions... I am not an electrician but I have a...
