Discuss My first soldering! in the Electrical Forum area at ElectriciansForums.net
Tomorrow I'll be making many joints in cables 0.5...6.0mm², I'll take pics.
Normally you have a slightly damp sponge (not a nylon one that melts) to wipe the tip, but a slightly damp cotton cloth should do instead.
Thanks, but no thanks. I need my trousers on.On site I've got into the habit of just wiping it on my jeans and carrying on, but that's probably not such a good idea if you wear those designer tradesmens trousers that are all the rage
Practice makes perfect.
Donkeys years back, I remember we were practising at tech and one thicko was totally baffled. One lad had brought some 60 amp fuse wire from work and we stood back giggling.
We used to have some big 400v 2 phase spot welders. They had two multi pin interconnecting sockets and plugs, army standard and murderHere's a practical example of an inline soldered joint in a 5-core screened cable to a readout encoder on a lathe. The cable had a fatigue break in the middle of a job, so I cut out as much of the worn section as possible and joined it back up. The inner braid screen is connected through (and sleeved, so there are two layers of insulation between it and the other conductors) but not reformed to shield the joint as there is another shield over the top. The joint was sleeved in adhesive heatshrink.
Reply to My first soldering! in the Electrical Forum area at ElectriciansForums.net
