Discuss My lights stopped work in the UK Electrical Forum area at ElectriciansForums.net
My kitchen lights (2 brand new led lights) both stopped working. Tried flipping the breaker and replacing the light switch. Nothing worked. I took a volt meter and checked the wiring to the switch, I can't get a reading, it appears that there is no power coming thru the wires (I'm an idiot and have very little knowledge of electrical work, although I know how to use a volt meter)
The breaker seems good and the other lights on that breaker seem to be working. Need any tips
Whoever installed the new lights needs to come back and have a good look.
I suspect they have a connection that is not actually connected properly.
How long has those brand new LED lights been installed. It sounds to me like your problem is in one of the lights. The switch is not going to just cut off the 2 lights unless there all all on 1 circuit
Reply to My lights stopped work in the UK Electrical Forum area at ElectriciansForums.net
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
I have recentley added a porch to my house it did not require building regs due to my original door stopping in place. The electrician has...
