Discuss NB40 Wylex in the UK Electrical Forum area at ElectriciansForums.net
Iona222
Trainee
Gents. Where can I get one of these, it's for a wife's shower keeps tripping. It's on a 30 amp needs up to 40amp.
Is there a rcbo fit this at all.
Cheers
Ebay is a little treasure trove of old mcbs and switchgear , it’s always my first port of call if I need a random old mcb or fuse
Cheers
I have never bought them from there, usually try keep all older stuff as I pull them out after paying 120 quid pop for QOE RCBOs for older boards. probably as cheap fitting a stand alone RCD enclosure next to board?
Reply to NB40 Wylex in the UK Electrical Forum area at ElectriciansForums.net
What are people fitting in the 3 phase range just lately, I've had a scan at various makes and it seems to be a ---- up between Hager and Wylex at...
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
