Discuss Need a deeper back box, what are my options? in the DIY Electrical Advice area at ElectriciansForums.net
I've swapped out a traditional switch for a smart switch. As you can see, the back box is nice and full, there's no chance it'd fit and I don't fancy pushing my luck and squashing everything.
I think there's breeze block right behind this box so I don't think chipping away for the additional depth is an option. Before I bin this new switch, are there any options around this?
I'm happy to stick a blanking plate on the front of it and make a second hole to house this smart switch and just the cables it needs, but not sure if that's a common approach or even if I can get everything I need to that second back box without it being busy again.
Any advice appreciated.
As above refit the old switch until better times, cables entering the top and bottom makes it a bit more tricky so expect some refinishing of the wall.
Thanks both!
You're right, electrician will be booked in as soon as this madness blows over.
In the meantime though someone sent me a link to a spacer which is a great idea so might look into that. Would need to be at least 20mm but I'm sure I can find one.
Reactions: DPG
Or two at 10mm.... a couple of long screws and you’re good to go.
good to see a smart switch question that doesn’t start “help, I need a neutral!”
haha god knows why I didn't think of that! Brilliant.
Thanks!
Don't worry, I went through my "I need a neutral" pain a couple of weeks ago! You'll notice there's no neutral going into that smart switch. It works on wizardry.
EDIT: I did notice there's a neutral there available to me, but there wasn't elsewhere and wanted my switches to match.
Reactions: DPG
Reply to Need a deeper back box, what are my options? in the DIY Electrical Advice area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
I'm trying to fit dimmer switches but there there isn't enough space in the back boxes. I have replaced some of the boxes with deeper units and...
Hi, I've bought a "yagusmart" smart switch from Amazon and it has no earth terminal. Although there are no metal facing parts I would think the...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
