Discuss Need a little help, can I add a second PIR with a single core line in (live) in the Lighting Forum area at ElectriciansForums.net
Welcome to the forum mate.
Theoretically, your diagram will work.
What cable you thinking of using?
So you show the outputs from the PIRs are linked, so all the LED lights will come on if either PIR is activated. Is this what you are after?
Thanks for the welcome.
The PIRs are linked so yes that’s exactly what’s needed, and I can use 1 core of a 1.5 x 3 core armoured cable, I known this is a bit over kill but it will run part outside and part underground.
Reply to Need a little help, can I add a second PIR with a single core line in (live) in the Lighting Forum area at ElectriciansForums.net
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
We have had RG11 installed in some flats for use with Virgin/Internet. It should I think have been RG6 but the guy at Virgin was insistent it...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Hey guys I'm going back into college and I have had some time off and behind work. I just can't get my head around this. 1 gang 2 way plate...
