Discuss [Need Advice] Reuse phone chargers in the UK Electrical Forum area at ElectriciansForums.net
O
Once
Hi everyone, I'm making a house model in which I use one VAC bulb and another one but uses DC source. What blocking me at the moment is the electric source of the VDC bulb. I want to use circle in phone charger (I have many of them, ones of Nokia 12xx) to transform VAC into VDC and I tried but it seems no results. I'm neither a pure electrician nor majoring in electrics. So hope that you can raise your voice and help me.
A cellphone charger does not just act like a normal transformer with a rectifier. It has sensing circuitry that constantly monitors the load (usually the battery) and adjusts its output automatically. It's possible it doesn't recognize the characteristics of your LED and is going into standby mode.
It might work if you include an old Nokia cellphone battery in the circuit but you would probably be better using an LED driver or even normal AA batteries of the correct DC voltage without a charger.
Reply to [Need Advice] Reuse phone chargers in the UK Electrical Forum area at ElectriciansForums.net
Hi, I’m after some advice for an existing car charger that’s on one of our newly inherited sites. We have a Rolec 2x 7.2kw pedestal charger, just...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
Let me say from the off that although I'm electrically competent I'll be getting a professional in to do the work. I just like to know the answers...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
