wildcardspv
- Reaction score
- 0
Hi,
I have a Beko OTF22300x double oven and need to replace the thermostat in the a main oven.
Problem is that I can't access the screws to remove the old thermostat from behind the control plate, as the plate seems to be made up of 2 panels which are really close and I can't separate them.
The thermostat screws are fastened through the inner panel but the outer panel covers them, so can't get to them.
I've attached some photos to show the control plate with the knobs removed, and also the inside of it which shows how close together the 2 panels are (top edge).
Does anyone know how to get these damn panels apart without damaging them, as this seems to be the only way I can see to do it!!!
Many thanks for reading this!!
