Discuss Need help with clean dB on retail unit in the UK Electrical Forum area at ElectriciansForums.net
Damian Petsas
Hi all , We are carrying out a refit on a retail unit and the client wants us to provide a clean dB for the till power and the data cab. Can anyone clarify best practise for configuring this in the install .
The site currently has a 3 phase incomer with 60a fuses at the distributors side.
We are intending to install a schneider acti 9 TPN 8 way board with a 125A 4pole switch isolator to feed the general lighting and power. .
The intention was to go Into Henley blocks from the meter and then split to the TPN and off to a single phase board for the clean power . Is this correct ?
Many concerns are
1. If I install like this will the phases not be unbalanced ?
2 am I better off supplying the clean dB from a MCB in the TPN board?
3 can anyone give me general advice on best practice for balancing 3 phase DBS.
i know this is a large topic .
Any advice and help would be grateful . Many thanks in Advance
well a dedicated supply and mcbs to provide power to kit like the pdq machine and the data cab . So in the event that the general power is interrupted it doesn't cause issues with the tills .i.e a mcb powering the ring . It's fairly common is supermarkets
I would recommend coming of your main distribution board to supply your Dedicated supply DB as Dilld says you could spred the load by the way you configure the main DB or you could fit a small 3 phase 4 way DB it depends how many circuits you need if its just a till socket and a coms cab just run 2 separate circuits from your main DB and not bother with the separate board ,Unless they want a last man out switch then that changes everything
They do want a last man out but I'm installing contractors for just the lighting for the last man out. Ok so the two options are feed db2(single phase clean dB) from mcb in TPN (db1) or to fit Henley blocks then From there feed db1 and db2 . Is that correct?
You need a main switch before the henly blocks in my opinion henly blocks look is a bit ruff so feed off You main DB As Dillb says see post 11
I've re read post 11 .dont mean to sound dumb but surely if iinstall with Helena blocks and feed both dbs . Each dB has a switch isolator therefore isolating the supply ? Or am I missing something here?
Whats Helena got to do with the job?
Reply to Need help with clean dB on retail unit in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
We are looking for a distribution board to provide 3 * 160A three-phase feeds, but they are basically redundant supply path options so max total...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
