Discuss Need help with new light switch in the Lighting Forum area at ElectriciansForums.net
Conner S.
Ok. I removed a dimmer to put a regular switch in. Installing a new ceiling fan and light. They have the power from box going to light, then switch, then to an outlet below the switch. The switch never controlled the outlet, just light. So can I just use a 4way to keep the flow going to the outlet and make it not control it? Just the ceiling fan?
If you want it permanently on there is no need to connect it through the switch just connect it to the supply hot wire.
Reply to Need help with new light switch in the Lighting Forum area at ElectriciansForums.net
Hi, I am installing a new bathroom fan. We had an electrician who ran 14/3 into a junction box. The black feeds a led light and the red was...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
