Discuss need some help ! Testers ! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
amberleaf
some questions I would like answered
1, extent & limitations agreed with ? person ordering the work ,
where can i find this !!! any down loads
2 , as am not a tester yet ! be kind
and how many Certificates in each sets ? where can I find this out 4/4 ,3/3 , 2/2 ,1/1 , or what
where can I find this out :eek:
Hi.
1. There is no download for this, the extent is how much of the installation that is covered by your certificate i.e if you have just completed a full istallation on a house then the extent would be - full installation within property.nOr for an additional socket onto an existing circuit the extent would be just that.
The limitations are parts of the installation that you cannot inspect or test i.e on a periodic cables under floors, in walls etc. Also the client may not want any disruption to a particular part of an installation so for instance you may be unable to isolate a circuit for dead tests, this would be a limitation agreed with them and noted on the cert. On a new installation cert there should be no limitations.
2. confused by what your asking, sorry.
question, 2
schedule of test results how many in a set all in ? 4/4
electrical installation certificates in a set all in ? 3/3
minor : how many in a set all in ? 2/2
periodic ? 0/0
Reply to need some help ! Testers ! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Refurbishment of dwelling has taken place and the clients insurance company requires a periodic inspection and test to be carried out, A new...
Hello, I had an eicr done in 2021and it passed with four C3 items. They recommend next test date to be in 3 years instead of 5 on the certificate...
I have been asked to look at this report as the customer has been given (in their words) 'A very high quote plus VAT'. It doesn't look well...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
