Discuss Need timeswitch for heaters......... in the Electrical Tools and Products area at ElectriciansForums.net
C
Crosswire
I have a customer who has some outdoor heaters (halogens, 2x 1400W) and requires a system where the heaters turn off after 15 mins whenever they are activated
I plan to use a relay/contacter to do this but need some kind of 'time delay' switch to operate the coil, and was thinking of using one of those circular push switches you sometimes see in office stairwells, or shared houses..
My question is : will this work , or can someone point me in the direction of a better 'time delay switch' to operate the heaters?
Reply to Need timeswitch for heaters......... in the Electrical Tools and Products area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Someone wants me to put a water heater(30 amps), range(40-50 amps) and dryer(30 amps) all on a single 60 amp circuit. I said that's a bad idea...
Hello, I’m not an electrician and I have a question in relation to Dimplex Duo300n. Some background information: a couple of months ago I have...
7K
B
Hi everyone, In the rear of the RR is the plug which connects to a remote controlled unit a telestart t90 switch box of some kind, a telestart...
At our church, one of the things I've done is sort out the heating wiring (as best I can for now). The schematic is as shown below. The theory...
