- Reaction score
- 6,362
Not quite as daft as it sounds, this follows from my thread a day ago. I need to find an electrical (ideally, gas could also be an option...) to heat a plastic bath tub of water to around 45C, and then maintain it. I've rejected the idea of using those deathtrap looking immersible elements that you plug in and throw in, for starters most of them seem to give up at around 35C. Don't have running water unless it's via a hosepipe so we can fill the tub initially. Considering possibly using a 7-8kw fixed element like we use for undersinks in WC's etc, or maybe a shower, but then effectively creating a loop system by having the inlet to it return from the tub - so once it's at temperature it's reliant on the built in thermostat just circulating hot water. This also has to be portable and idiot proof (and I mean idiot).
Open to all ideas, suggestions and products!
R.
R.
