Discuss Need to find out if I can run my plasma cutter on an existing circuit. in the UK Electrical Forum area at ElectriciansForums.net
WfpEnt
I just picked up a Thermal Dynamics SL100 plasma cutter. I have 220 circuit in my shop but I don't think its up to the task. Its about a 40 foot run to the shop from my 200 amp panel. Currently the circuit has a two pole 15 amp breaker with 10-3 wire. The requirements are below. Can I just upgrade the breaker? What size? Do I need to run a whole new circuit?
  • Cutmaster82ServiceManual.pdf
Sorry, wrong diagram....
It sounds like you have old single phase wiring, typically 208 now requires 4 wires. 2 hots a neutral and ground. Also it is always good to use factory recommendations. This would require new cable as well as a new breaker. Also this device can be used with different voltages and requires this to be selected. All this can get difficult quick, it may be worth while seeking out a local electrician.
Dseelye it’s all 240/120vac single phase The only way he could have 208vac would have to come from a 3 phase system.
Ah, that seems to be correct my apologies. I figured it was a single phase system. For some reason I always considered someone saying 208,220,230,240 all referenced the same 120/240 system, however just researched this further and "208 single phase" references a configuration of a three phase system. Thanks for the clarification!
Reply to Need to find out if I can run my plasma cutter on an existing circuit. in the UK Electrical Forum area at ElectriciansForums.net
Hello! My shop is currently on a single 15 amp circuit. Is like to upgrade it at the main home panel to a 30 amp. Do I just need to run 10 gauge...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
I would like to ask advice on a breaker size. Back in 2001 I turned my garage into a woodworking shop with several 240v machines. To power them I...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Apologies up front but I'm a DIYer and only got 1 reply on that forum so trying here. I'm in Ontario Canada where a homeowner can do there own...
