Discuss need to install 3 sky points in a house in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
C
charlalberts
HI,
I was wondering if anyone could give me advice on installing 3 sky points in a domestic house.
Would i just need to run shotgun cable from the main sky point to the 3 individual rooms that need the points?
Any help would be most appreciated
Shotgun cable from dish to each point wold be required for Sky+.
You can run a single satellite cable for standard sky / satalite boxes. The dish will need to have an LNB with enought outlets for each cable.
As above ^^^^
The tuning process for a channel frequency involves frequency switching the LNB band (hi/lo). So you need an outlet for each box direct from the LNB. As said two outlets at each point if it's sky+
Reply to need to install 3 sky points in a house in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
