Discuss NEMA 6-50 to 6-20 outlet question in the UK Electrical Forum area at ElectriciansForums.net
JSolomon
Hi All, I am new to the group and just a DIYer hoping to get some advice. My garage has been wired for my air compressor and the outlet is what appears to be a NEMA 6-20. It is wired to my panel with two 15 amp fuses and is marked 220v by the electrician that wired it years ago. I just purchased a welder that requires a NEMA 6-50P (looks like a typical clothes dryer plug). My question is: can I run a 6-50P outlet by adding it to the existing 6-20 outlet? So in other words I would just add the 6-50 outlet adjacent to the existing 6-20 outlet. Or is this a situation where I just need to have an additional circuit added to accommodate the welder? Probably a reasonably stupid question for this group, but just trying to determine how to go about it, or at least be somewhat knowledgeable if I hire an electrician. Thanks much in advance.
My friend no you can’t each price of equipment needs it’s own circuit. You sure can’t run a welder pulling that kind of amps. Your air compressor is only 20 amps at 240vac and your welder will blow those fuses.
Reply to NEMA 6-50 to 6-20 outlet question in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
20 Amp outlet (240v) appears to be connected to 30 amp breaker. Is this safe? Was hoping to use the outlet for an EV Charger. I am new to the...
Hi - I am adding a NEMA 6-50r outlet in the garage for my welder. I pulled 6/3 Romex back to the panel where I will install a 50 amp breaker...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
