Discuss neon testers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
pushrod
Yes i know they should be put in the bin. Anyway if they work by a high resistance letting only a tiny current flow through you, can anyone explain to me why i got these results when i touched it onto the connections on a wall light that was switched on.
phase - red glow (as expected)
neutral - no light ( i thought all the current would still be there? Has all the pd been dropped across the bulb - so even though there is a current there is no energy?)
CPC - v dim glow ????
When i put a voltage tester (measuring 3.5V to 230V) across each pair i got a voltage registering on all three pairs. Can the CPC be at a higher potential than the neutral?
Need i say more, if you put it on the other side of a closed light switch it will glow:D
Your neutral IS effectively AT earth potential or should be or else your light wouldn't be lit!!
If you go to consumer unit and disconnect the neutral then test it you will see that NOW it IS live and the light isn't lit!
(not suggesting that you should try this at home,leaving a live wire dangling!!!)
Your voltage on the cpc-yes it is closer to the live and guess what it has NO insulation. What we test when we meggar,is insulation resistance test,,how much, if you like electricity can escape,this can increase if there is moisture or even paint on the cables,and breakdown increases with age and use.This is why we should actually DO the insulation resistance test,rather than simply writing >200 every time.
As for phase tester screwdrivers,mine lights up when I touch the door handle on my living room.
Anyone can make a neon light by rubbing on trousers Vic Reeves style on shooting stars...neons are for making holes in wood a bit like a bradall, thats all
Are we talking those crappy little screwdriver things with the neons in or votsticks, I had a cheapo voltstick from toolstation, lit up whatever i touched, are there better ones on the market that you can trust?
The fluke Volt alerts are good as they have sound and light, but they should only be used for indication and not for proving dead.
I can't stress that enough!!!!!!!!
Reply to neon testers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Having a challenge understanding the concept behind why when you measure across line and neutral (live circuit) using voltage indicators we have...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Today I went to fix a minor loose screw on something and after switching off, etc, got out my Martindale VT12 continuity & voltage tester and...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
Today I was doing an EICR and went around a couple sockets with a Megger MST220 socket tester just to see if there was anything obvious, all three...
