Discuss Nest heat link help please in the UK Electrical Forum area at ElectriciansForums.net
Could someone please help me on the wiring:
I have oil central heating and am looking to remove my programmer and replace with a nest thermostat, just need help wiring the heat link. Please see attached pictures
Reply to Nest heat link help please in the UK Electrical Forum area at ElectriciansForums.net
Hi as per title I'm building a sublimation heat press. i have a 1000mm x 250mm x 8mm sheet of cast aluminium. i will be using a thermostatically...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
