Discuss Nest Hello transformer/chime. in the UK Electrical Forum area at ElectriciansForums.net
Afternoon everyone.
A customer has just purchased this video doorbell and asked me to fit to the existing chime, but It appears to be incompatible.
I only have mains and push button connections. There is no access to the transformer terminals.
Does anyone know of an all in one transformer/chime that is compatible to avoid having a transformer mounted next to a separate chime unit?
Cheers everyone.
What about this
https://www.NoLinkingToThis/p/british-general-8-24v-8-va-bell-transformer-module/8707p
From memory i think 16v is minimum
Currently installed is a Deta c3500. This is an all in one unit. I really need a similar, but compatible product or I will end up with a din rail transformer mounted next to the chime.
Is the door bell fed at the CU or off the lights?
If fed from the CU is there space for the din rail transformer in there?
You could then fit a door bell without a built in transformer.
Or could use alexa echo
Would a CSU be able to accommodate a DIN style tranny?
Thanks everyone. Supply is not from the CU.
Going down the route of New enclosure next to the wall chime.
Customer didn't want this , hence me asking if anyone had experience of a compatible all in one unit.
Excuse my ignorance but why has the new enclosure got to be fitted next to the chime? Can't you mount it away from it and just feed the output from the transformer to the chime? You have to run a mains cable to the enclosure and the output to the chime anyway.
Reply to Nest Hello transformer/chime. in the UK Electrical Forum area at ElectriciansForums.net
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
Our old Friedland chime all too often now emits a only faint "ding"- because the person at the door (usually a delivery driver) just "dabs" at...
Hello All, Incase this reaches other non UK residents to confirm this doorbell has been fitted in England it regard to electricity distribution...
4K
Hi, I have purchased a Ring Video Doorbell in the UK, and am looking to install it. I live in a New build property and the transformer to the...
4K
Hi. Here's some background info. I am located in the United States, and have had a Nest Hello video doorbell working perfectly for a couple of...
8K
