Hi, hopefully one of you knowledgeable chaps can help me. Looking to think slightly out the box here. I already use nest thermostats and protects which work great and tick all the boxes for me. We are moving home soon and will be installing underfloor heating that Nest out the box doesn't support. Is there some kind of device that can be the middle man here between the nest control panel and the underfloor electric heating?
Here is a snippet from the FAQ and the full link here:
https://nest.com/uk/support/article...-compatible-with-the-Nest-Learning-Thermostat
[h=2]Which heating systems aren’t compatible with the Nest Thermostat?[/h]There are two main reasons that a heating system may not be compatible with Nest Thermostat:
1) The system requires high current switching.
While most heating systems are high voltage (usually 230V), usually they only use a little bit of current at a time (up to 3A). However, some systems that are high voltage use a higher current (sometimes as high as 16A or higher) - for example, electric radiators or electric underfloor systems. High current underfloor and radiator systems are common in France, especially in apartment buildings. Thermostats are designed to handle either low current or high current. The Nest Thermostat only supports low current systems since they are by far the most common.
