Discuss New Cable to Old in the UK Electrical Forum area at ElectriciansForums.net
perfectly safe as long as the existing cable is in sound condition. more importantly is what cable are you intending to use for the spur; what, if any containment do you propose; what load will it feed; are you fusing down with a FCU; and finally, have you the test gear to test the work, and are you competent to do it?I have been asked by my brother to take a spur from the ring main to a summer house from the house (7m) T&E. BUT I have since found out that the house has not be rewired for about 40yrs. Is it safe to connect a 2019 T&E to an older Ring main. Consumer main fuse 45A
missed that.he could be confused with a cooker or shower circuit. another thing i missed was to ask if circuit was RCD protected. i blame lack of sleep/food/beer.Are you saying that the ring main breaker size is 45A?
Providing the JB if used is Accessible, if not MF, if taken from an existing socket outlet, that is part of the RFC and not a spur, how many sockets are intended to be installed in the Summer house? more than 1 then a fused spur should be used at the take off from the RF, as per Appendix 15 BS7671.perfectly safe as long as the existing cable is in sound condition. more importantly is what cable are you intending to use for the spur; what, if any containment do you propose; what load will it feed; are you fusing down with a FCU; and finally, have you the test gear to test the work, and are you competent to do it?
sorry I forgot to mention one Double socketI have been asked by my brother to take a spur from the ring main to a summer house from the house (7m) T&E. BUT I have since found out that the house has not be rewired for about 40yrs. Is it safe to connect a 2019 T&E to an older Ring main. Consumer main fuse 45A
Thank you for your help.Ps are you sure about the main fuse being 45A?
I have seen old properties with 60A supplies but never less than that.
You are looking at adding
10A hot tub
8A fan heater
6A oil heater
2A fridge (estimate)
13A double socket (estimate) patio heater etc
Call that little lot 40A and it is almost the total of the incoming supply.
You say you are a trainee, why not use this as an exercise in how to plan and calculate a new installation and see what you come up with.
There are loads of us on here that will give you pointers and show where your calls might not be correct.
. I am not confident to plumb in a 16a breaker into the main consumer board. As you can see it would need to be replaced.
I thought if I spur off the ring main and put a 13a 2g RCD switched plug socket in and advise him to have the house rewire then it could have a direct cable from the consumer box.
I believe 7m is the distance and not the cable csa.7mm cable? Are you sure that's right? Providing you have tested the circuit with your mft and everything is ok then yeah it's fine to connect to it. Presumably through a 13a spur?
Reply to New Cable to Old in the UK Electrical Forum area at ElectriciansForums.net
