- Reaction score
- 0
can I use 4/0 use 2 3 strand cable in 2 1/2 " conduit 160' to power 200 amp panel then power modular home 50' from garage in vermont do I need a shut off in between or is this ok
Discuss new connection to garage and then to modular home in the UK Electrical Forum area at ElectriciansForums.net
In a single family dwelling you need 2/0 copper times 3 and with a # 6 ground and a 2 inch conduit which is good and when you feed the modular home panel from your main panel. All you are probably going to need is to install a 100 amp double pole breaker in your main panel to feed the modular home . I don’t use aluminum wiring it’s a pain in the butt to bend in such a small space. For your situation The modular home needs a 100 amp sub panel and feed it with # 3 THHN wire and a # 6 ground. This panel needs to also have a main breaker. Good luckcan I use 4/0 use 2 3 strand cable in 2 1/2 " conduit 160' to power 200 amp panel then power modular home 50' from garage in vermont do I need a shut off in between or is this ok
Reply to new connection to garage and then to modular home in the UK Electrical Forum area at ElectriciansForums.net
