Discuss New exposed brick wall in the UK Electrical Forum area at ElectriciansForums.net
Hi,
We are in the middle of building our kitchen extension, we have decided to have an exposed internal brick wall constructed as we have some excellent brick spare.
The external block wall is up and before we put up the internal brick wall we were going to install the cables for: fridge/freezer, dishwasher, 3 double sockets and an oven feed. This will stop the need to surface mount onto the brick.
I was planning to run the T&E in individual 25mm pvc or flexible conduit attached to the external wall. Then bring them through the new brick wall where needed still in the conduit.
The cavity will be insulated which I know is another issue with heat so we made need to use larger conductors than usual.
We have engaged a registered electrician who will be doing a site visit but I thought I would like to get some other opinions or alternative ways of doing this.
Thanks,
Phil
Was an exposed wall in the original design and taken into account when heat loss calcs were done?
You may find that Building Control will want the wall Dry lined and with insulation.
Reply to New exposed brick wall in the UK Electrical Forum area at ElectriciansForums.net
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
I would like to hide the cable to an EV charger. The consumer unit, meter cabinet and charger would all be on the same wall. About 5 metres from...
Hello. I'll apologize to start with as due to my lack of knowledge on the matter I'm likely to waffle a bit and call everything by the wrong name...
I am getting ready to install a new wall oven that's about 4 ft closer to the panel than the old stove. I have about 4 ft extra cable with the...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
