Discuss New guy looking for advice on installing smart light switch. in the The Welcome Forum area at ElectriciansForums.net
Hello everybody,
Just needed some expert advice on installing some smart light switches. As you can see from the images it looks like I have a neutral at the switch but where does the 2 wires going into 1 go and where does the wire going into L go on the smart light switch?
You are going to need a test meter.
Either the single brown, or the two browns will be the permaanent live.
Use your test meter to find out. One will have a permanaent 230v reading (live feed) and the other will go on and off with the switch (thats the switched live out to the light itself.)
If I were a betting man (I'm not) I would expect the two browns to be the permanent live. But there's no guarantees with this sort of thing.
Thanks for the reply. Looks like I'll have to buy a test meter then to make sure
It's an essential tool, if you are doing electrical work! They are cheap enough at Screwfix/the sheds, etc....
You'll need to check at each switch, in any case.
PS, hope you have a neutral at each switch?
I'll go to screwfix after work thanks.
I haven't checked the other light switches yet to make sure they've got a neutral but I will do before I start buying the smart light switches. Do you not think there will be a neutral at every switch??
Agree. Most likely the 2 browns together are the permanent live and the single brown is switched live.
If you’re buying a test meter, get a good one. A neon screwdriver type cannot be trusted.
It’ll do. I’m not a LAP fan, but adequate for what you want to do.
Some of my switches have a neutral ( the new ones that I installed) most of them don’t.
There’s only one way to find out, test and inspection.
Make sure you set the multimeter to the correct range before testing a live cable.
There was a recent thread about a new multimeter, wrong setting, a live cable and a big bang.
Test between a brown live, and the blue neutrals in the connector block.
Once you find out which is live, and which is switched live, isolate the circuit before changing the switch. … Had to say that
Ok mate thanks for the advice.
Reply to New guy looking for advice on installing smart light switch. in the The Welcome Forum area at ElectriciansForums.net
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
I can't seem to find the right answer for a smart switch installation for a light that has THREE switches. There's conflicting information, and...
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
