Discuss New house unknown circuits in the UK Electrical Forum area at ElectriciansForums.net
Hi - I just moved into a new house. The box has a circuit labeled "Central Vac" and 2 labeled "Septic." The house does not have a central vacuum. I do have a septic system that as far as I know does not use a pump or any electrical power. Any idea why these circuits would be there?
could be that they were once in use but are now redundant.
Any toilets in strange locations ?
Thanks for replying.
There is a basement bathroom with an ejector pump that was added maybe 2-3 years after construction. I assumed that was run off of the same circuit as the basement lights and stuff. There is a sump pit as well but they never put a pump in there. Maybe it was for that, just weird they would label it Septic instead of Sump Pump.
Switch the circuits off and see if anything stops working. Might be used for something else now but haven't been relabelled.
dudebro houses do have vacuum systems and I agree it might not be working right and just abandon it. As far as septic I have heard of sump pumps in basements that is prone to take on water. My advise is cut them off and see what happens or something stops working. Good luck
Reply to New house unknown circuits in the UK Electrical Forum area at ElectriciansForums.net
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
My friend just moved into a new build flat and its for a disabled person with a hydraulic lift to go to the upper floor. There was/is a leak...
Just under 2 years ago my central HVAC died. I wanted to go with a heat pump because the only appliance in the whole house that used natural gas...
