Discuss New light switch problem in the DIY Electrical Advice area at ElectriciansForums.net
L
lekkie1
I am trying to change a white light switch for a new silver one next to the front door. It has a light in the switch so I can see when the exterior light is left on. It was working fine but I am trying to instal the new silver light switch but it seem to be working back to front. When the neon light is showing on the switch, the light outside is off and vice versa. I am really stumped?
probably because you have the neon wired across the L and S/L. the may not be a N available at the switch.
Reply to New light switch problem in the DIY Electrical Advice area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi guys. I will start by apologizing for the elementary question. I'm sure you get them often. The chandelier is in a hallway controlled by a...
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
