Discuss New NHBC guidance for fire rated downlights / hoods in the The Welcome Forum area at ElectriciansForums.net
For many years the market for fire rated downlights has been highly confusing with many manufacturers making claims but not always having the technical data to back up these claims.
The NHBC has just launched new guidance to cover the use of fire rated downlights which makes it very clear that only correctly tested products can be used in the type of floor construction in which they are being fitted.
Specific reference is made to the type of joists being used as light weight joists are now the norm for many types of construction and these need different tests to the old solid timber joists.
http://www.nhbc.co.uk/Builders/ProductsandServices/TechZone/NHBCStandards/TechnicalGuidanceDocuments/64/filedownload,84608,en.pdf
Take care to make sure what you are fitting is correctly tested.
Wetroom Store - Network Wetroom Suppliers
Midwest
I always fitted fire rated down lights whatever, although some on here suggest its not necessary in single fire zones, i.e. a domestic dwelling.
Or are you talking of the specific type testing of a 'fire rated' luminaire?
  • #4
The new guidance refers to "intermediate floors" above and below 5M and refers specifically to recessed fittings.
Leesparkykent
Mod
Mentor
Supporter
And that we are still allowed open stair cases in homes ....
I’m not 100 percent certain why but on a new build I’ve recently done the choices were to encase the stair case so it had a doorway or put a sprinkler system in on the staircase. They opted for the sprinkler system and kept it all open. There were 3 floors in total. From what I believe a 1st floor widow can be used as a fire escape but anything above 1st floor a window can’t be classed as a fire escape so if you have a loft conversion done or build convert a house that has more than ground and 1st floor then the stairs is the sole means of escape so the immediate rooms that are accessed from the sole means of escape have to be fire doors.
  • #8
Strange how there is no restrictions on the use of plastic vent grilles and pipe
Totally agree, however I have recently been involved in fire tests (using metal web joists)which involved other types of ceiling penetration such as fans and air valves and would assume that the same will happen to them as it has to the recessed lights, same applies to soil pipes which run vertically through floors.
They are protected or unprotected stairwells :D
Welchyboy1
Unless a very specific circumstance, there should be no real reason why anybody is using non-fire rated fittings nowadays surely
I thought the days of the nasty 12v open backed halogens were well and truly over with
telectrix
Mentor
I don't know but I've been told...………...its about premature collapse of structural lumber.
you mean that new builds have undersized joists, spaced to far apart, construction done as cheaply as possible to barely meet safety standards? well, i'll go to our (solidly built) stairs. :D:D:D:D.
SparkyAndGeorge
Advent Win
Agree with this guy. Nowadays they're virtually the same cost anyway.
PEG
Mentor
I wouldn't waste any time worrying about the NHBC....they are are a ridiculous and worthless entity,with no power or interest,in the things you would consider that they should be concerned with.
.....They do a thriving trade in stickers,though...
Midwest
My parents house was built in 1898. Bet its stairs were built better than your stairs. ;)
Reply to New NHBC guidance for fire rated downlights / hoods in the The Welcome Forum area at ElectriciansForums.net
Test Meter - Forum Sponsors since 2007!
Top Bottom
